problems with a moto 4
Old Sep 18, 2007 | 09:01 PM
AJtheATCman's Avatar
Default problems with a moto 4
Most of the time I only get one spark at the plug when I press the start button. But some times it will start right up and run for 15-20 mins before it shutts off. the ignition coil tested good.The source and pickup coil have just been replaced. Does this sound like a CDI problem? Thanks for your help.
Old Sep 18, 2007 | 11:24 PM
Raptor450's Avatar
what are you doing working on a moto-4 when you have all of those ATC's to play with?jk The next thing I would check would be the stator.
Old Sep 19, 2007 | 12:00 AM
HONDA CRUSHER 93's Avatar
what year is it on my 86 225, it would do the same thing and i found out that the hot wire that goes to the battery was inbetween the teminal and the posotive wire. it was also loose. it switched them around and tightened them up and she ran great. but it might not be the same for you because my sister has an 88 200 and it doesn't have the seperate hot wire.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
TheHood
Jul 26, 2015 09:51 AM
hondarider1234
Jul 21, 2015 11:53 PM
