Do you change your air filter
<div class="FTQUOTE"><begin quote>Originally posted by: Brnxadk
Is there a certain type of oil?</end quote></div>
Yes, there is a specific Air filter oil you are supposed to use. That being said I do know quite a few guys that will use motor oil, however due to the weight of motor oil it tends to seep to the bottom leaving the top of the filter dry and succeptable to dirt.
Is this a foam reusable filter? My atv has a foam filter over a metal holder. I pull the foam off and clean it, re-oil it and put it back on the holder. I put a small amount of grease on the rubber gasket that seals against the side of the air box. The only reason to replace it would be if it was damaged. Also you can get spray on filter oil that is easy to apply but more expensive. I was told by a long time dirt biker that 30wt motor oil is just fine.
Filter oil sure feels a lot more tacky (traps more dirt) than regular motor oil and it just isn't that expensive so I use it.
I purchased one liter of Twin Air filter oil for $15 and it lasted through several air filter cleanings. Pretty cheap insurance to protect your engine if you ask me.
house1
08-09-2015 10:49 PM
