Rims?????
Old Oct 23, 2007 | 03:09 PM
87 warrior's Avatar
Default Rims?????
ok, i've made my choice by going with the GNCC tires. but now i just have to find a rim that will hold up and not bend easy or at all. i saw that douglas and ITP both have steel replacement rims. what is your take on them? the c-series was one of my choices for a rim also. i like the way look and they sound stronger than the .190 T9 pro series. i think this is the hard part finding rims that won't bend.
Old Oct 23, 2007 | 06:21 PM
Raptor450's Avatar
Default Rims?????
The C-series are very strong rims. I'm not sure about steel rims. They may be strong, but they are probably much heavier than aluminum - not a good thing. Again, you can't go wrong with the Baja's, stock Yamaha wheels (Banshee, Warrior, Raptor 660 & 700, or YFZ 450) or the C-series. The Hiper Wheels are probably good, too, but who's got $800 to spend on a set of ATV wheels? Mainly you just want to find a rim with a strong outer edge. All of the rims have a strong enough center to hold up to just about everything.
Old Oct 23, 2007 | 06:45 PM
87 warrior's Avatar
Default Rims?????
well i looked at the c-series and they only have it in 9x8 not 9x9. the steel rims they said are considerable thicker than OEM rims. so i'm guessing they would be heavier than aluminum. i just want a rim that's going to hold up and not brake the bank. i don't want a rim that's too heavy ethier. what kinda rims do you have?
Old Oct 23, 2007 | 06:58 PM
Raptor450's Avatar
Default Rims?????
Me again. I have the factory 1997 Warrior wheels. Thay have been thru it and are still goin' strong. It's hard to beat the factory wheels!
Old Oct 23, 2007 | 07:03 PM
  #15
87 warrior's Avatar
Default Rims?????
are they aluminum? my front rims feel pretty light and are the stock rims so i'm guessing they are aluminum. i wonder if you can still get the stock rims off a newer warrior or off a raptor....?
Old Oct 23, 2007 | 09:37 PM
  #16
STRAIGHTUPDAHILL's Avatar
Default Rims?????
YUP!
Old Oct 23, 2007 | 10:30 PM
  #17
Raptor450's Avatar
Default Rims?????
Yeah, they are aluminum. Ebay has a ton of factory wheels on there. Thanks Hill for the support, I don't feel so abandoned and lonely now!
Old Oct 23, 2007 | 11:16 PM
  #18
87 warrior's Avatar
Default Rims?????
ok cool i'll check it out. thnx alot for your help guys i appreciate it
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
fd24
Jan 16, 2019 08:59 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
