Blaster problem
Old Oct 26, 2007 | 02:13 PM
imsam77's Avatar
Default Blaster problem
the slower the engine turns, the more air will leak out...no little/no compression, no ignition, you gotta make sure it's spinning fast enough
Old Oct 26, 2007 | 04:43 PM
STRAIGHTUPDAHILL's Avatar
in aircraft and now it has caught on to cars..is using a differential compression tester...more reliable
Old Oct 29, 2007 | 04:34 AM
hotblooded's Avatar
The jetting and needle position are very important given the fact of the non stock motor. If the plug looks fine the problem in initial throttle response could be in the air/fuel adjustment screw. I might be wrong but I believe that this is the only time that particular adjstment comes into play is throttle response.
Frisky2050
Apr 9, 2020 11:19 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
joeyupton
Jul 14, 2015 11:51 AM
