Twist to Push throttle........
Old Nov 4, 2007 | 06:47 PM
Tpxsss's Avatar
Default Twist to Push throttle........
I bought a 660 with a twist throttle but I want to convert it back to a push. I bought the push assembly and new throttle cables. Im thinking I need to get new grips? Am I missing anything?
Old Nov 4, 2007 | 06:57 PM
Myclock187's Avatar
Usually the grips just slip on and off (not too easily though) and you can re-use the same one...otherwise grips are not too expensive to buy. Also if you like having the twist throttle sometimes but prefer the thumb throttle most the time there is something called the dual gasser that is really cool and is two in one... here's a link. You can find them on ebay too...
Terry Cable Dual Gasser
Old Nov 5, 2007 | 12:01 PM
maddog56's Avatar
You can't re-use a grip on the throttle side, the grip is sized larger to fit over the throttle tube for a twist and therefore will properly fit the handlebar without the throttle tube.
You'll need a new grip on the right side but since they come in pairs you might as well replace both.
Lucas Bohanan
Sep 29, 2015 01:16 AM
tysonbully
Sep 28, 2015 02:30 AM
2many2ride
Sep 27, 2015 04:35 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
89Lt250r
Sep 7, 2015 07:53 PM
