blaster
Old Nov 21, 2007 | 06:59 PM
pm6balla's Avatar
Default blaster
I just got a 04 blaster that has been raced and whenever i pick up the front end of the quad the rims seem like they are loose and they kind of jiggle. I'm pretty sure that i need a knew ball join or replacing the hub bearings but im not sure.If you know what the problem is i would appreciate the help. Thanks.....
Old Nov 21, 2007 | 07:15 PM
2STROKEFUMES's Avatar
Default blaster
You probably need new front end bushings. Take your A Arms off and see how damaged the are. Is there any axle play? You may need new carrier bearings as well. You should check that too. Chances are if the previous owner raced it and never replaced the bushings it got very unstable so he decided to unload it. Its cheap and easy if you do it yourself and the A-Arms are stock 35-45 for all of them I believe there are 16 total for the front end. A-Arms like Lonestar call for bushings straight from Lonestar and they are like 80 bones.
Old Nov 21, 2007 | 08:49 PM
STRAIGHTUPDAHILL's Avatar
Default blaster
lug nuts
wheel bearings
ball joints
bushings..the choice is yours...only you can see whats moving,not us
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
