Blaster only idles will not rev - help!
Old Dec 4, 2007 | 11:38 PM
jimjet's Avatar
Default Blaster only idles will not rev - help!
I have a 2000 Blaster that I recently purchased. It would only idle when purchased and had other problems so I did a complete rebuild: crank. crank bearings, piston, rings, bored, honed, new seals, new gaskets etc. Put everything back together and still only idles. I thought the TORS might be the problem - does anyone have GOOd instructions for disconnection. The ambiguous instructions I found were: disconnect throttle switch and twist those wires together to make a complete circuit, disconnect carb wire (no splicing wires), certain instructions said disconnect the brain too? Good instructions would be helpful because these did not work. Any other thoughts why this bike wont rev beyond idle? Thanks Guys!
Old Dec 5, 2007 | 10:49 AM
asfasasu3's Avatar
Ours has done the same thing this past spring. Since I have already taken off all the tors stuff, I was a little puzzled as to why. I finially disconected the parking brake rev limiter and it solved our problem. The wire going to it had became pinched and caused it to short out, thus not letting it rev. I disconected it under the front hood. I just traced the wires from the handle bars back to a connection under the hood, to a small black box. (thats also how I found the pinched spot) You could start unhooking it at the handle bars and work your way down to the box. If that doesn't work, you can put it back rather easy. I'll look for better detailed info on the tors removel for that year of blaster.
Old Dec 5, 2007 | 02:05 PM
CTATV's Avatar
Yamaha's ebrake sensor on the wolverine,banshee,blaster,warrior has been plagued with badness evilness and the likes...
I had issues and had much better luck after disconnecting the switch on my wolverine. its always a good start with stuttering issues
<div class="FTQUOTE"><begin quote>Originally posted by: asfasasu3
Ours has done the same thing this past spring. Since I have already taken off all the tors stuff, I was a little puzzled as to why. I finially disconected the parking brake rev limiter and it solved our problem. The wire going to it had became pinched and caused it to short out, thus not letting it rev. I disconected it under the front hood. I just traced the wires from the handle bars back to a connection under the hood, to a small black box. (thats also how I found the pinched spot) You could start unhooking it at the handle bars and work your way down to the box. If that doesn't work, you can put it back rather easy. I'll look for better detailed info on the tors removel for that year of blaster.</end quote></div>
Old Dec 5, 2007 | 03:06 PM
jimjet's Avatar
Thanks! From what I can gather they didn't start the brake rev limiter untill 2002 or 2003 and my bike is a 2000!?. I will do some investigation on that. Thanks for your help.
Old Dec 5, 2007 | 04:01 PM
CTATV's Avatar
maybe different for the blaster but my buddy has a 99 warrior and i have a 2001 wolvy both have the sensor
franklyme
Oct 21, 2016 07:18 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
