Poping at high RPM
Old Dec 9, 2007 | 04:09 PM
poldo123's Avatar
Default Poping at high RPM
I have a 98 Big Bear 4x4. When running at high RMPs, the engine makes a popping noise. Also, it will die out sometimes if you let it idle down to fast.
It has sat up for a few years. The muffler is busted. I have a new one on the way. Could the problems be just from the muffler?
Thanks
Adam
Old Dec 9, 2007 | 05:43 PM
STRAIGHTUPDAHILL's Avatar
explain busted
Old Dec 9, 2007 | 05:53 PM
poldo123's Avatar
Center of muffler rusted out and eventually fell apart. The pipe that curves down at the end of the pipe fell out.
Old Dec 9, 2007 | 06:44 PM
that will make it run lean....fix it and it should be better
Old Dec 10, 2007 | 12:04 AM
alba301's Avatar
it also is reducing backpressure which will make it stall
Old Dec 10, 2007 | 07:17 AM
poldo123's Avatar
Thanks for the help. It will be Christmas before I get to put it all together. Will let you know how it goes.
Old Dec 10, 2007 | 10:07 AM
panikrev's Avatar
It's probably time to check your valve clearances also. If your clearances get too tight, it will cause the same problem. Also, how long has it been running lean w/o the silencer? It's surprising how quickly you can burn the valves and seats. Run a compression test-if it's low, put some oil in the cylinder and do it again. If the compression comes up, it's do to ring and cylinder wear. If the compression doesn't change, it's time for a valve job.Good luck!
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
