TRI-z Help
Old Dec 12, 2007 | 05:53 PM
ragdog's Avatar
Default TRI-z Help
in the proccess of rebulding a tri-z, one big question i have is when i got trike a tank was fitted above motor in false fuel tank.
i have the original that i have refitted under set but it doesent look like it will feed fuel by gravity very well as the tank is only a couple of inchs above carb, the trike is now fitted with yz 250 bike engine.
was their a mechanical or vacum pump fitted to the original tri-z engine????
Or does gravity work?? I cant see it working cus a up hill climb it will put the carb above the fuel tank??
any help will be recieved with thanks
Old Dec 12, 2007 | 07:08 PM
Raptor450's Avatar
Default TRI-z Help
I'm not an engineer but I understand as long as the fuel level in the tank is above the hose it will still flow even uphill. I had a Tri-Z years ago and never had a problem and the YZ 250 engine is almost identical to the Tri-Z engine.
CRamshaw777
Jul 18, 2015 05:46 PM
thebutelr
ATC 3-Wheelers
15
Dec 30, 2006 03:46 AM
Michiganredneck
ATC 3-Wheelers
Oct 28, 2003 09:01 PM
Michiganredneck
Oct 17, 2003 08:52 AM
okie
Mar 16, 2003 10:33 AM
