warrior runnin crappy
Old Dec 16, 2007 | 08:00 PM
disturbedru's Avatar
Default warrior runnin crappy
i have a warrior that was boggin down at full throttle and now it just idles if you hit the gas it just boggs and pops
Old Dec 16, 2007 | 10:52 PM
Raptor450's Avatar
Check the parking brake mechanism and the switches at the clutch lever. I would recomend just getting rid of all that useless crap.
Old Dec 17, 2007 | 08:05 AM
ok thanks it also does it just in neutral
Old Dec 17, 2007 | 10:37 AM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
Older warriors have an issue with grounds in their electical systems....Soemthing in teh back of my mind says it was centered around teh kill switches or something like that.... You might try something there. Plus Yamaha are notorious for carb float needles sticking. You might want to take a look at the jets etc and spray some cleaner around. Do the cheap stuff first.
Old Dec 20, 2007 | 09:18 PM
what would make it spit and sputter when you take it out on the road but not when your in the dirt?
Old Dec 21, 2007 | 03:03 PM
YurFatMom's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: disturbedru
what would make it spit and sputter when you take it out on the road but not when your in the dirt?</end quote></div>
If you stab the gas on the road, the engine could flood, because the engine cant spin up fast enough(Tires arent spinnin) to suck in enough air to counteract the fuel from the accelerator pump.
What happens if you slowly roll on the throttle?
Old Dec 21, 2007 | 05:39 PM
mikem92's Avatar
My old raptor 80 has done that very same thing several times. I ended up having to clean the carb and there was something clogging the jets. Dirt and stuff got in either from bad gas or crappy (CRAPPY) air filter. My air filtter was in front too so all the mud and stuff flew right into it. Anyways, i would take a look at the carb and make sure you can see through the jets.
Old Dec 22, 2007 | 10:43 AM
ill check that stuff and get back with yall never thought about the motor not spinning up quick enough.
Reactant
Mar 30, 2022 02:08 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
