Carb needle issues
Old Dec 16, 2007 | 10:47 PM
getblown's Avatar
Default Carb needle issues
I am having problems with my jet needle holder, the plastic retainer that holds the needle in place. It seems to keep poping off. My raptor will be running great, then all of a sudden it will just fall on it face. I pull the vacuum chamber cover off and that holder is bouncing around. Should i go get a new piston valve, thinking the old one is worn out(not holding on tightly to that retainer). Any insight would be great, thanks, Terry
Old Dec 16, 2007 | 10:56 PM
STRAIGHTUPDAHILL's Avatar
will a metal c clip fit?
Old Dec 16, 2007 | 11:01 PM
getblown's Avatar
I am not sure what you mean, the needle it's self has the c clip, I am having troubles with that white plastic holder that keeps the needle down. It has an o-ring on it and pushes down and clips in to the piston valve(black diaphram)
Old Dec 17, 2007 | 10:57 AM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
I don't know what the deal is with Yamaha's carbs... I have 3 Yammys in the shed, and have owned 5 over all. I also have a few Hondas in there as well. I consistantly have issues with carbs on all my Yamahas.. and have not had a single problem with the Hondas. For some reason, I always have problems with stuck float needles, and gummed up carbs on the Yamahas while the ondas just keep going. I sure wish Yamaha would take note and fix this issue, as I really love my Yamahas other wise. I use the Stabil, service the Air Filters etc.. and still have issues. The Service manager says bad gas... but when I fill teh Handas from teh same pump on teh same day, and they don't have issues, I am not buying that...
Good luck on your issue.
Jmuddin284
Jan 19, 2026 07:16 AM
traumajunkie
Jul 5, 2015 03:03 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
