how to test a cdi box ?
Old Jan 27, 2008 | 03:10 AM
Chase07's Avatar
Default how to test a cdi box ?
how can you teat a cdi and regulator on a yamaha warrior 350 thanks guys
Old Jan 27, 2008 | 04:14 AM
Raptor450's Avatar
This should help. Scroll down to the electrical chapter (7 I think) and it will tell you. Wire colors may not be exactly the same because this manual may not be for your year model.http://www.sandwizards.com/Service_Manuals/warrior.pdf
Old Jan 27, 2008 | 08:24 PM
recon99's Avatar
Best, easiest way is to just swap them out on a running machine and see if they work. There really isn't a good or easy way to test the cdi. Very rarely does a stock one fail, and when it does it's usually catastrophic burnout, and you can actually smell that they are burnt.
Old Jan 27, 2008 | 08:48 PM
Chase07's Avatar
ok thanks just wasnt sure how to check them. i think my problem is the kill switch/ start stop switch. i tried a different starter clyc. i think the switch is shot because it dosent switch power from one side to the other
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
