Problems with Beartracker
Old Jan 30, 2008 | 06:44 PM
YAMAHARIDER703's Avatar
Default Problems with Beartracker
Alright. I went out to my shop and got my Beartracker out, took 30 min to start, but ran fine after it started. Then when I put it up, I noticed that the neutral light wasn't working. But the reverse light did. I thought that was weird, so I cut it off and tried to start it back up. Electric start didn't work. The battery is fine. I charged it, and still nothing. I don't know what's wrong. The electric start won't work, and the neutral light won't work. Reverse will though. And from my knowledge, the Beartracker's electric start won't work when the fourwheeler isn't in neutral. So, dang! Help me out here!
Old Jan 30, 2008 | 09:11 PM
devill's Avatar
i have a similar prob with a honda fourtrax and as far as i can tell (and from what other people are tellin me )its got something to do with a short in the harness or the regulator is bad.it wouldnt start with start button but it will start with the pull cord. will your yamaha start with the pull cord????
Old Jan 30, 2008 | 10:51 PM
Yeah it will. I just thought it was weird that the neutral light wouldn't come on, then the electric start wouldn't work.
Old Jan 31, 2008 | 11:22 AM
devill's Avatar
did u try unplugging you regulator to see if your neutral light would come on???when i unplugged mine my neutral light would come on and when i plugged it in again it would go off so my problem is somewhere around the regulator....or regulator wires....
Old Feb 1, 2008 | 08:19 AM
Cmarti's Avatar
Check the nuetral switch connection. Is it a crimp connection to the switch? Sometimes crud up or work loose.
Old Jul 13, 2010 | 02:25 PM
innernasty's Avatar
I bet is one of the fuses on your solenoid check them mine did the same replaced the fuse and now it burns good but dont really know what happens to make it blow prolly a short.
Old Jul 13, 2010 | 11:27 PM
Sgt_Morrow's Avatar
There is a wire right above the oil drain plug and the shifter. Make sure that it is plug up or not lose or anything. Also make sure it's not dirty. Try pulling the brake handle when you try to start the ATV. Like you were trying to start it in gear. Let me know what happens.
Old Jul 14, 2010 | 08:27 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default Light
It doesn't seem like that light not working would prevent the quad from starting. I would not think that the starter or that system would know whether the neutral light is on...seems the quad should know whether it is in neutral to start without having to see the light. I would agree with the last guy and try the rear brake pulled and see if that jumps the problem!
Mudslinger2
Old Jul 14, 2010 | 08:35 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Could be the relay assy. beside of solenoild
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
