RAPTOR 660 REVERSE SWITCH
Old Feb 3, 2008 | 05:17 PM
MMCK8039's Avatar
Default RAPTOR 660 REVERSE SWITCH
I am having another problem with the 2004 Raptor 660. Whenever I go to Reverse it spits and sputters and don't want to move at all. This happened to me earlier in all gears and I disconnected the emergency brake and fixed the problem. Now, it only happens in reverse. Reverse switch bad? Please give me your take on this. Just started happening....
2006 Kaw Prairie 700
2004 Yam Raptor 660R
2002 Yam Warrior 350
Old Feb 4, 2008 | 02:43 AM
chabill's Avatar
I HAD THE SAME PROBLEM WITH MY 02 660R RAPTOR THERE IS 2 WIRES ON THE HANDLE BARS WHERE THE FRONT BRAKES ARE PROBABLY THE PARK BRAKE ARM THAT MOVES WHEN U PUT THE PARK BRAKE ON IS NOT PUSHED ALL THE WAY BACK
IF I PUT MY PARK BRAKE ON AND TRY TO REV THE ENGINE IT SPITS AND SPUTTERS
SO MAKE SURE THE LEVER THAT ENGAGES THE PARK BRAKE IS NOT PUSHED OUT ANY
HOPE I MADE SENSE AND THIS HELPS YOU LET ME KNOW
Old Feb 4, 2008 | 02:46 AM
chabill's Avatar
THER IS A REV LIMITER ON IT WHEN U GO 2 REVERSE
IT MIGHT BE GOING BAD
Old Feb 4, 2008 | 03:58 AM
skii0's Avatar
thats the rev limiter...there are ways to bypass it with kits you can buy...or you can do it yourself by splicing wires...someone should know how this is done....
Old Feb 10, 2008 | 01:46 AM
HappaRap's Avatar
Lazy Boy Rider!
That's your reverse rev limiter kicking in, I put a rev limiter bypass on my 02, works great, you can buy them online.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Derek Allen
Jul 22, 2015 09:25 PM
black_thunder
Jul 22, 2015 06:01 PM
