Yz80 qustion
Old Feb 22, 2008 | 12:48 AM
asdfgh1's Avatar
Default Yz80 qustion
No after it dries it still dose the same thing I am going to take the carb off and let it soack in this one thing i have and see if that helps it. Can you adjust the reed valves? if so How. thanks
<span class="FTHighlightFont"> sorry for all the qustions just want to get back up and riding sinse it snowed.</span ft>
Old Feb 22, 2008 | 01:05 AM
itch's Avatar
remove and clean the jets in the carb especially the pilot jet
Old Feb 22, 2008 | 01:10 AM
asdfgh1's Avatar
ok. i got the carb right next to me just pulled it off whene you tim the carb upside down is the suppose to be gas coming out if so its not coming out at all but on one of the jets its drip drip drip and so on
Old Feb 22, 2008 | 01:15 AM
asdfgh1's Avatar
Im going to try and explain this the b est way i can the two sides that come out of the carb ( side that gose into the reeds and side the gose into the air box) and in the center where the needle valve gose in for the gast to come out i just noticed thers is gas floating on top of it than i wipe it off and it dose it again i think the carburator is getting flooded but gas is clean and it has plastic tank is that a reason why it is running half way?
Old Feb 22, 2008 | 04:22 PM
  #15
Raptor450's Avatar
When you clean the carb, are you taking the jets out and blowing them out with air and spraying carb cleaner in them? If not that's what you need to do. It's normal for gas to run out from everywhere if you got the carb turned over or off-level. If the carb is filling up with too much gas then your float level is adjusted too high or there's a piece of trash stuck in the float needle valve or the float valve is worn out.
Old Feb 22, 2008 | 07:03 PM
  #16
asdfgh1's Avatar
yes i did all that i think it was clogged because whene it was tiped upside down no gas came out just a couple drops so i am going to get ready to see what it will do now. thanks
Old Feb 22, 2008 | 10:05 PM
  #17
speedyman12345's Avatar
okay if your carb is flooding with gas its your float not adjusted to the right height, not sure what kinda carb you have but you need to find out and ask what the float bowl should be set at
Old Feb 23, 2008 | 03:30 PM
  #18
asdfgh1's Avatar
i just got the carb put back togeather after cleaning all the jets and the carb and it still dose the same thing so the carb is eliminated now what else is there to do to it has anyone ever had this problem before
Old May 24, 2008 | 01:16 AM
  #19
asdfgh1's Avatar
after a couple months of not responding i got smarter at 2 strokes i took the head off and at the exuast side of the piston ther is a whole and part of the piston is gone luckly it went into the exaust so i am going to order a piston tomorw
Old May 24, 2008 | 06:31 PM
  #20
xxxalpinexxx80's Avatar
hmm my 2 stroke blaster had a simular problem but not really, there is a lot of fuel where the exauhst side is, and it is leaking so i think i need a new top end gasketand pistons
yamahaesq
Aug 5, 2009 04:16 PM
Offroader22
Jul 21, 2005 11:10 PM
DieselTech
Jun 4, 2005 03:05 PM
DANO38
Mar 8, 2005 02:04 AM
