HELP!! Starter questions
Old Feb 24, 2008 | 05:25 PM
recon99's Avatar
Default HELP!! Starter questions
What are you jumping it from?
Old Feb 24, 2008 | 06:30 PM
beefy46172's Avatar
Loves To Ride!
Tap on the starter while trying to start it and see what happens. A had a load of troubles with the starter system on my Warrior and ended up with a weak battery and starter, which made it a PITA to diagnose.
Old Feb 24, 2008 | 11:25 PM
TtOrMaMnY's Avatar
i am thinking it is a weak battery and bad solenoid.
when i plug a jumper cable to the battery, it turns over a little bit easier but still get a bunch of clicking for the solenoid. after a couple of short burst attempts the atv will start up with the electric starter.
once i remove the jumper cables it will be weak again and still get a bunch of clicking for the solenoid.
Old Feb 24, 2008 | 11:29 PM
recon99's Avatar
Ok, so i'm gonna ask the same damn question again... what are you jumping it from? One of those stupid little jump packs or are you jumping it from a car battery?
Old Feb 24, 2008 | 11:30 PM
  #15
recon99's Avatar
I doubt it's your solenoid at this point. Usually either a solenoid works perfectly, or it doesn't do anything at all. I've never seen one that just kinda worked like you're seeing.
Old Feb 24, 2008 | 11:55 PM
  #16
beefy46172's Avatar
Loves To Ride!
<div class="FTQUOTE"><begin quote>Originally posted by: recon99
I doubt it's your solenoid at this point. Usually either a solenoid works perfectly, or it doesn't do anything at all. I've never seen one that just kinda worked like you're seeing.</end quote></div>
I am thinking the same thing. At this point it really just sounds like a weak battery; dependent on the jump source.
Old Feb 25, 2008 | 01:38 PM
  #17
TtOrMaMnY's Avatar
i used one of those sears craftsman battery charger/jump starter that you plug in to an electric outlet. when i used that to jump start it and held in the starter button then i hear the solenoid just clicking and starter will turn once in awhile. when i press the starter button in bursts then after several attempts it will finally start.
Old Feb 25, 2008 | 05:02 PM
  #18
recon99's Avatar
Sounds like you just have a dead battery and nothing else. Those plug in jump starters really don't have near enough power to jump start a dead battery on their power alone. Try jumping it off a car or lawn mower or something, or just take the battery to an auto parts store and get it load tested such we've already suggested...
Old Feb 25, 2008 | 06:36 PM
  #19
TtOrMaMnY's Avatar
will do. going after work today. thanks guys. i will let you know how it goes.
Old Mar 3, 2008 | 12:45 AM
  #20
TtOrMaMnY's Avatar
hey guys!! so i put in the new battery and it works like a charm!! thanks for all your help and support!
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
mudpig79
Jul 13, 2015 03:31 PM
