Blaster carb problems
Old Feb 28, 2008 | 08:06 PM
igotacracker's Avatar
Default Blaster carb problems
any one have any problems with there carb on a blaster as to not make it start?
that seems to be the problem on mine but i dont know what to do to fix it.
Old Feb 28, 2008 | 08:09 PM
asdfgh1's Avatar
no but i have that same problem on my yz80
Old Feb 28, 2008 | 08:18 PM
87 warrior's Avatar
if you haven't cleaned it out real good that may be your problem. there's probably a bunch of gunk in there that clogged the jets up. making it not start.
Old Feb 28, 2008 | 08:23 PM
no i just took it apart cleaned it out and everything , put it back
together , started first kick, ran for a little, then shut off and wont
turn back on again...
Old Feb 28, 2008 | 08:52 PM
87 warrior's Avatar
is it getting fuel? maybe your floats are stuck or you have a clogged fuel line. it's probably not the problem but it's worth taking a look at.
Old Feb 28, 2008 | 09:28 PM
qsportgoat's Avatar
its happened to me a couple of times after i cleaned or jetted a carb,the floats stick.i just tapped on the side of the fuel bowl with a screwdriver handle.hope this helps also check your gas tank vent line if its clogged gas wont leave your tank in the amount needed
Old Mar 5, 2008 | 12:39 PM
chuckneste's Avatar
Hello,
Can you remove the fuel line going to the carb from the petcock /shut off valve in the open position to see if gas is flowing freely to the carb. If the flow is good, maybe the float is casuing it to flood out/ starve. When it dies and if you remove the spark plug is it wet or gas fouled? Is the air cleaner perhaps clogged and not getting sufficient air flow? I dont know if I should recommend this being a noob myself but if you remove the air cleaner element and spray starting fluid in the port, Will it turn over?
Chuck
Old Mar 5, 2008 | 11:57 PM
Terrellster's Avatar
Like has been said,......I think you've got a stuck float.
Now there is a possibility there's a problem with your TORS system (if it's still there,.... you know,.....That odd box atop the Carb?) also take the timem to test the Throttle poprtion of TORS and anything else related. I found broken wires while troubleshooting my older Blaster, sometimes It fire a round or two, then just quit like yours.
I had mine leave me a mile and some from my truck once. After all my checks were done, I found the coil had an internal short. After all it was 18yrs old,......coils go bad on NEW CARS all the time. I was impressed with the Blaster coil lasting this long.
If you don't have the book get a Manual that has all the wiring and t-shooting info (how to test switches and circuits) and go over all of it if the items above don't get it running. I recommend the Haynes for procedures tot test the TORS stuff.
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
