engine noise
Old Mar 18, 2008 | 03:52 PM
haulinas's Avatar
Default engine noise
engine has a tick replaced whole upper half of engine, piston, rings, valves ,guides seals timing chain, springs and cam. any answers what the noise could be
Old Mar 18, 2008 | 03:54 PM
pmcc37's Avatar
what kinda bike, and could be your rockers or valve adjustment
Old Mar 18, 2008 | 04:05 PM
haulinas's Avatar
1987 warrior replaced rockers, lash is correct
Old Mar 18, 2008 | 04:08 PM
pmcc37's Avatar
needs break in time then. is it a loud ticking noise or suttle. When I rebuilt mine it did that for the first hour then quit.
Old Mar 18, 2008 | 04:11 PM
haulinas's Avatar
had same noise before rebuild
Old Mar 18, 2008 | 04:17 PM
pmcc37's Avatar
well it may be something in the lower in, I don't know would have to hear it to give a idea.
Did you replace the rocker arms themselves, the could be bad.
Old Mar 18, 2008 | 04:24 PM
haulinas's Avatar
yes replaced rocker. do you think it could be crank bearings
Old Mar 18, 2008 | 08:17 PM
woodsjunky's Avatar
when i rebuilt my warrior engine it had a few ticks i had to work out but sounds like yours may be the start of a bad crank berring
Old Mar 18, 2008 | 10:21 PM
pmcc37's Avatar
could be, was there slack in the rod (side to side) when you went to rebuild it..
greg74
Sep 10, 2019 03:03 PM
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
