oil cooler for a warrior
Old Mar 21, 2008 | 12:58 PM
  #21
Octane2079's Avatar
Default oil cooler for a warrior
You do one or the other. The big bear is nice because its bolt on and go, but it is more pricey. The clutch cover method is cheaper to do and you get the cooled oil directly to the crankshaft bearing
Old Mar 21, 2008 | 01:06 PM
  #22
pmcc37's Avatar
I may go the clutch cover way... And still do the shifter, it looks like it makes it easier to shift.. Is that so?
Old Mar 21, 2008 | 01:08 PM
  #23
pmcc37's Avatar
on the clutch cover setup, what pumps the oil through the cooler?
Old Mar 21, 2008 | 05:55 PM
  #24
Octane2079's Avatar
The oil pump, you block off the oil galley between the two fittings and then the oil can only go through the lines to the cooler and then back. There is a good write up about it on bluetraxx with a list of everything you need.
Also you don't have to make a direct shifter if your not going to use the big bear setup, you can just put a yfz, banshee, or yz250 dirtbike shifter right onto the shaft and go, makes your shifts much more crisp and gears easier to find
Old Mar 21, 2008 | 10:07 PM
  #25
pmcc37's Avatar
aren't they set down further under the bike? Which would make it harder to get tho the shifter?
Old Mar 21, 2008 | 11:37 PM
  #26
Octane2079's Avatar
I know my yz250 shifter works great, all the yz 4 stroke dirtbike shifters and the yfz450 shfiter definitely bolt right up and make shifting alot more crisp.
Old Mar 24, 2008 | 06:19 PM
  #27
MHScass's Avatar
Dose the oil have any troble geting to the cooler?
Old Mar 25, 2008 | 02:18 AM
  #28
Octane2079's Avatar
Not if you install everything correctly
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
