94 warrior350 clutch dragging and hard to fine neutral
Old Mar 30, 2008 | 11:05 PM
rwarrior350's Avatar
Default 94 warrior350 clutch dragging and hard to fine neutral
The clutch does not completely release for a few seconds when you pull on the lever. I have installed a new cable and lubed it with wd-40. The cutch is adjusted properly, also,it is hard to get it into neutral once the engine gets hot, which is typical of an warrior, but it seams to be getting worse. Ive had this warrior since 98 , and it still has the orginal tires and sprockets on it, I dont ride it very much,and it still looks almost new. Does anyone now the cure for this problem.
Old Apr 2, 2008 | 04:30 PM
dksturgeon's Avatar
I'm having this same problem on my 2000 blaster.....any help would be great.
Old Apr 2, 2008 | 06:47 PM
P1FOXRIDER's Avatar
i had a warrior and it did the same thing, do you have the parking brake blocked off? Mine would do that and i would let it roll in first and pop it a few times and you could see the parking brake snap back, then it would work fine for a while. But if you have eliminated the parking brake, then i don't know.
Old Apr 2, 2008 | 07:19 PM
woodsjunky's Avatar
A SIMPLE CLUTCH ADJUSTMENT WILL FIX THAT PROBLEM!
Old Apr 2, 2008 | 07:23 PM
woodsjunky's Avatar
YOUR CLUCH IS NOT ADJUSTED PROPERLY IT IS DRAGGING IT MIGHT BE FINE WHEN U RIDE BUT IT HAS A SWEET SPOT FIND IT MINE DID THE SAME THING CLUTTTTTTTTTTTTTTTTTTTTCCCCCCCCCCCCCCCCHHHHHHHHHHH HHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
Old Apr 2, 2008 | 08:44 PM
dksturgeon's Avatar
I have adjusted it at the clutch lever and it didnt help at all. It worked fine 2 days ago and after I parked it the next day the clutch wont work at all. It starts fine in neutral and as soon as you shift to a gear it trys to jump and dies.
Old Apr 2, 2008 | 09:30 PM
woodsjunky's Avatar
time to take it apart if u think u covered all the basics,but the adjustment at the handle is only to reduce a loose lever, all clutches have a adjustment near the clutch in the cable. if all seems well and the clutchlever seems to have a normal amount of tention u should pull the clutch and inspect. let us know what u find
Old Apr 2, 2008 | 09:36 PM
woodsjunky's Avatar
also if u use thick oil i have seen the disks stick together almost sounds like ur pressure plate works normal but all ur disks are not separating properly pull them out and brakecleen them if they look good replace if thet dont buy a new kit [cheap!] make shure u keep them in a stack front to back
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
tporath
Jul 11, 2015 12:31 PM
200es
Jul 10, 2015 09:09 AM
Albertascramblerx
Jul 8, 2015 11:56 PM
