AIR PROBLEM
Old Apr 14, 2008 | 09:58 AM
P1FOXRIDER's Avatar
Default AIR PROBLEM
ok, i have a Mikuni 38mm carb, the factory on my blaster is a 26mm. before i decided to use my factory air box i had an open 6in filter attached to the carb. well i finally modified my air box to work with the larger carb, but now its running rich. before with the open cone i had a #350 main jet, and the e-clip set on the third notch of the needle, and it ran perfect. now with the restricted air-flow, i have a #340 with the clip set on the top notch of the needle, and it is running extremely rich. So here's my question:
1) should i go back to the open cone, put on an outerwears prefilter, and change the main jet and needle setting back
2) or should i get a smaller jet, and use the factory box
Old Apr 15, 2008 | 10:59 AM
P1FOXRIDER's Avatar
Default AIR PROBLEM
ok decided to go with the factory air box, i dropped down to a #280 main jet and it is running great, but the clip is on the top nitch of the needle. i was thinking about going down to a #260 for a little more adjustability in the clip. what do you guys think?
Old Apr 15, 2008 | 11:39 AM
pmcc37's Avatar
Default AIR PROBLEM
here is my suggestion with any carbs try it and see what happens...
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
