2001 Warrior
Old May 5, 2008 | 12:28 PM
Biggsw784's Avatar
Default 2001 Warrior
Having to rebuild the rear swing arm on my warrior. Having a hard time trying to get the bolt out of the pivot part where the swing arm is bolted to the frame. The nut came off very easily but the bolt will not come out. I used a hammer with the nut loosely on the bolt and used a impact on the bolt but it just turns??? Is there a secert to getting this bolt out???? Thanks for any help guys... Casey
Old May 5, 2008 | 04:37 PM
pmcc37's Avatar
you can beat on it all you want, I had to torch mine out and buy a new(used swingarm.... Its just about impossible to get out, I spent 3 weeks, usilg every type of penetrating oil to loosen it up, and it finally took 2 mins witha cutting torch to get it out, It was rusted completely solid once i got it out...
Old May 5, 2008 | 07:59 PM
Biggsw784's Avatar
thanks man. i ended up using a saws all to get it out.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
