660 grizz
i have a 660 grizz it likes to over heat sometimes took it in for a recall and had the side farings replaced but still getting hot or when playing in the mud any ideas besides moving the radiator to the top of the front rack
yea the fan runs and i also let the fan run after i turn the four wheeler off i have noticed it likes to heat at lower speeds or on long hills and i keep a check on the coolant i havent noticed the levels dropping or anything
Is it really overheating? My 02 does the same, the fan runs quite a bit but it doesn't overheat where it is boiling of smoking. I had the recall done after I did it myself, long story, and it doesn't stumble,vapor lock, anymore. They do have a tendency to run pretty warm though.
I think the oil recommended in the owner's manual should be fine. I would agree with the mud clog though. I would take a hose and squirt it out real good (yes, I'm still talking about the radiator).
<div class="FTQUOTE"><begin quote>Originally posted by: JDQuadRider
I think the oil recommended in the owner's manual should be fine. I would agree with the mud clog though. I would take a hose and squirt it out real good (yes, I'm still talking about the radiator).</end quote></div>
The owners manual does recommend 20W40 (20W50 -older Yamalube) Above 40 (F). It all depends on where you live and the temperatures you ride... I agree that 10W30 is more of an "all-season" oil... but I run the 20W50 spring/summer/fall.
i try not to burry it up to the radiator but it does happen lol but i do keep it sprayed out good and clean for the most part and i did change the oil and went to the 20w 50 yamalube it dont do it everytime i ride but on steep inclines or long up hill pulls at low speed it seems to get hot idk
