warrior not running
Old Nov 6, 2008 | 04:29 PM
Andrew's Avatar
Default warrior not running
its a 04 i know it has good compression and it correct the fuel/air mixer and the jets are right
Old Nov 6, 2008 | 07:15 PM
Funeral Home guy's Avatar
I have a Warrior and had the same problem. Take the bowl off and pull your float out. Clean the Float needle and the whole the float needle goes in. Mine had alot of yellow buildup and it would not allow the needle to close all the way and was flooding it out bad. Good Luck
Old Nov 6, 2008 | 09:27 PM
Also (not being a smart ***) but my brother in law hooked is gas line up in the wrong place and had the same problem. Check that.
Old Nov 7, 2008 | 01:19 AM
Andrew's Avatar
I just rebuilt the carb and I hooked ever thing up right and the needle close all the way. but thanks for all the help but im just takein it to the shop two morrow and see whats up
Old Nov 7, 2008 | 04:41 PM
  #15
91Warrior357's Avatar
so you know the bowl isnt hanging up on anything? because if your fuel bowl is at the wrong height that can be a problem with it pouring in too much fuel, also the pin that slides through holding the bowl on make sure its all the way through or it will hit the side of the bowl and hang it up, and try afjusting your fuel screw in or out to see if it will fire up.
njrider64
Jul 4, 2017 01:40 AM
tpd270
Jul 1, 2015 08:18 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
dunc_n
Aug 26, 1999 09:32 PM
