Warrior 350 Carb
I just rejeted my Carb. I had put in a new piston and bored it .20 over. So i uped the size of the main jet and also backed out the Air Flow screw 1/4. I also decided while i had the carb off to clean it very well. I sprayed Carb Cleaner in it and let is sit for about 24 hours. I did dump it out before reinstalling. When i fired it up it ran great with good power and also very good throttle response (witch it didnt have before) The only problem i have is it is smoking a little with a white smoke and has a aweful smell. Smokes a little while idleing but a good bit more when you are on the throttle. I let it run 10 min or so. I was wondering could this be the carb cleaner in my carb trying to burn out. Or could it be the setting on the jets are off some?
GregM
Mar 6, 2018 06:53 AM
