04 Grizzly 660 Questions!?
Old Dec 10, 2008 | 06:18 PM
boosted_d16's Avatar
Default 04 Grizzly 660 Questions!?
Okay so I have a 04 Grizzly 660 and I got water in the automatic belt and now it hits the rev at like 15mph tops. I pulled the drain plug and a bunch of water came out but still won't do more than about 15mph in high range. Do I need to pull the cover off and see whats going on? Please give me some advice! I found where the water is coming from, one of my snorkel hoses had a hole in it.
Also after a little research I found out where my high RPM studder is coming from, Steam? I saw a couple threads about people drilling holes in a cover or something? Mine does this bad when in the mud. Also some advice would be greatly appriciated. -TJay
Old Dec 10, 2008 | 10:03 PM
Some1 please help, I pulled the cover and when i give it put it under a strain sitting still it does slip, Is there away to tighten or will i just have to spend $110 on a new oem belt? I read the dayco belts SUCK. Anything else I need to do when replacing it? I saw something about using high temp marine grease on something? But what parts do i greasE? Thanks -TJay
Old Dec 10, 2008 | 10:34 PM
cluby's Avatar
what you have to do is take you clutchs off and clean them, the "grizzly grease" has came out of the drive clutch when you got water inside. Pretty easy repair but messy. If you take it into your dealer it should only take them an hour to an hour an a half
Old Dec 10, 2008 | 11:11 PM
Cluby,
I think I can do the fix, Just need to get some more details on what to do. So do I need the "Ultramatic grease" Or will the high temp marine grease work? Also Both the front and back clutches? Which numbers in this Diagram do I grease?
http://www.bikebandit.com/hous...ematic/m8690sch297242
I just dont want to grease up a moving part that isn't supposed to be greased and it start slipping again. Thanks -TJay
Old Dec 12, 2008 | 12:11 AM
cluby's Avatar
Yep that's what it's called now. Far as where the grease goes, mainly just in where the weights are, about a spray can top cap full. I put a small amount in the center where it slides on the shaft.
I think you may be better off though if you just take it into your dealer, cann't really mess it up but got the feeling that your not sure about your mechaincal abilties
Old Dec 12, 2008 | 12:17 AM
Lol I'm sure about my mechanical abilities, I took it all apart today cleaned up the weights and re greased everything and its better than ever. Thanks!
Old Dec 18, 2008 | 06:58 PM
grizzwizard's Avatar
i now this is old but just seeing how ur belt is. U need gorilla grease for ur weights
also go 2 grizzhopper.com for the rev limter
Old Dec 18, 2008 | 08:45 PM
Well my belt is good, I re greased the weights and everything all upp and its better than ever.
Old Dec 22, 2008 | 10:50 AM
Deer Slayer's Avatar
do you happen to havea maint manual for yor grizz
cornermike
Sep 10, 2015 08:30 AM
Rooky
Sep 9, 2015 03:16 AM
rawbdiggity
Sep 7, 2015 12:05 PM
Elkaholic
Sep 6, 2015 02:44 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
