Big Warrior problems
Old Dec 17, 2008 | 09:08 AM
xtremeatvclub's Avatar
Default Big Warrior problems
I have a 1998 warrior and the other day while riding it, I heard a CLANKING noise, so I shut it down. My dad and I was told from another brand dealer that Warriors are notorious for their rod bearings going out. Is this true? I got onto Parts Unlimited and priced a heavy duty crank, rod assembly. (+/- $300)
Are yamaha engines that bad to tear into with the transmission being a part of the engine, and with the split casing?
I can use any help and knowlege anyone has on this!
Old Dec 17, 2008 | 10:24 AM
Politically Incorrect's Avatar
Warriors are not notorious for the crank going out. The internal workings of the Warrior engine are bullett proof (except maybe for the starter clutch). I would pull the top end apart and see what the problem is before I bought any parts. If it is the rod bearing (which I highly doubt unless you ran it low in oil) the top end will probably have to be bored and a new piston install, costing another $250.
The Warrior engines are fairly easy to work on. You can download a complete manual from sandwizards.com/tips&tricks. I have always removed my engines from the frame, removed the tope end, and pay a shop to split the cases and install the crank. It only cost me $140 for them to do the work @ $45/hr, I would say that's cheap insurance to know that all the little pieces in the cases are installed correctly.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
