And the Warrior Saga starts
Old Jan 30, 2009 | 08:59 PM
Raptor450's Avatar
Default And the Warrior Saga starts
sandwizards.com/tips&tricks - you can download a free manual to tell you how to check everything. You will need a volt/ohm meter to do the tests. Just make sure the manual is the right year for your's, the ohm readings could be different for different years.
Old Feb 1, 2009 | 07:02 PM
ATV24/7's Avatar
i would put in new crank bearings and then do a HMF pipe, Weiasco piston, cam or just rebuild it all stock.
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
