2005 wolverine will idle only
Old Feb 2, 2009 | 10:47 AM
bigwave's Avatar
From: South Central Illinois, NO where near Chicago, that's not my Illinois
Default 2005 wolverine will idle only
We were out riding the other day and my sons 350 wolverine was running fine then all at once it sputtered and died. Now it will idle only, it will start right up and run at idle all day but as soon as you give it throttle it sputters and dies. I've drained the fuel, thinking it cold be bad gas, I drained the carb but have not yet removed it for cleaning.
Anyone had this happen before? Where do I start looking?
Old Feb 2, 2009 | 10:53 AM
UGLY88's Avatar
Check the parking brake safety switch connection. If the parking brake is applied it will not let the machine rev or drive. It is a safety device to keep operators from pulling away with the Brake on. Make sure the P-brake is off completely and the switch is not engaged. If that does not work, unplug it completely from the harness under the plastic up front and don't forget to release the P-brake.
Hope this helps.
Old Feb 2, 2009 | 06:21 PM
bigwave's Avatar
Ya, I messed with the parking brake for a while, I thought the same thing, my old polaris scrambler was terrible about that in the winter.
I'll recheck again.
Thanks
fordfaithful21
Dec 7, 2015 05:52 PM
sleepyva
Sep 2, 2015 06:32 PM
sportsman2005
Technical and How-To Articles
Aug 19, 2015 10:52 AM
tporath
Jul 11, 2015 12:31 PM
