Help me Diagnose this problem. 98 Warrior.
Old Feb 7, 2009 | 03:29 AM
Wookie11's Avatar
Default Help me Diagnose this problem. 98 Warrior.
I am having problems with my warrior actually fireing up. If I crank on the electric start it turns over but doesnt fire up. And unfortunately i do not have a pull start. It is almost like the battery is ****, but it is only about 3 months old. If I hook jumper cables from my car to the battery it fires right up. I do not get it. I know its probably nothing to big, but i figure i'll ask on here. Your all usually pretty helpful. I can tell the difference in the speed it turns over when its being jumped and when its not. Obviously it turns over much slower when not being jumped. I've also just recently 2 months ago replaced the stator, so i know its not that. I'm not completely excludeing the possibility of getting a falty battery, but let me know what you all think. Mark
Old Feb 7, 2009 | 04:05 PM
Dune Rat 2008's Avatar
did you check the water in the battery cuz if its low you wont have a good charge and wont have any cranking power
Old Feb 7, 2009 | 04:21 PM
ftwflh's Avatar
How cold is it where you are ? Our Warrior does the same thing when it is real cold.
Old Feb 7, 2009 | 07:27 PM
hotblooded's Avatar
If you hooked a car battery to it very long you made need a new one anyhow. I found personally that it is just toooooo many amps.
Old Feb 8, 2009 | 10:14 AM
beefy46172's Avatar
Loves To Ride!
<div class="FTQUOTE"><begin quote>Originally posted by: hotblooded
If you hooked a car battery to it very long you made need a new one anyhow. I found personally that it is just toooooo many amps.</end quote></div>
Um, no. There is NO harm in jumping an ATV with a car battery, and do not argue, the issue has been thoroughly exhausted on this forum. Anyhow, put the battery on an overnight trickle charge and make sure it is full of acid/water. If it still will not start after that then you have a bad battery.
Old Feb 9, 2009 | 03:29 AM
Wookie11's Avatar
It is pretty cold here. Around 0 degrees. That may just be my problem.
Old Feb 9, 2009 | 05:56 AM
ftwflh's Avatar
Once it warms up it should start.The battery could have a weak cell
Customer Service #1
May 15, 2020 08:46 AM
Beeline08
Nov 11, 2016 04:00 PM
shimanok2
Jan 29, 2016 07:37 PM
01ssls1
Sep 22, 2015 06:50 AM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
