02 warrior locked engine
Old Mar 9, 2009 | 11:24 AM
dsteele1981's Avatar
Default 02 warrior locked engine
i was riding my warrior and the engine locked up on me i got it home and unlocked it by puting oil down the cylinder and worked the crank shaft. the bike was full of oil i was wondering why it could have locked up on me. there was alot of metal shavings in the oil basket and filter.
Old Mar 9, 2009 | 12:58 PM
91Warrior357's Avatar
prolly the thrust washers that are on the crank, was it a shiney metal?
Old Mar 9, 2009 | 12:59 PM
yeah and there was alot
Old Mar 9, 2009 | 01:04 PM
thats how mine blew up, its gonna need a rebuild then, the thrust washers are what is in between the rod and the crank assembly and its like a bearing for the rod and crank, i got my crank split installed a new rod and piston and cleaned all the shavings out of it real good, specially in the oil pump there was a good bit, then i put mine back together.
Old Mar 9, 2009 | 01:17 PM
you know about how much it will cost at a shop?
Old Mar 9, 2009 | 09:33 PM
mmm im not sure because this was when i worked at a dealer and got discounts, i dont work there anymore but they still cut me discounts, i got a rebuilt crank trued and everything along with a new rod and it was like 150 bucks than i just installed it myself, if you got a shop to do it all it would be more for sure, its different in certain areas but id say a rough guess is like 500 bucks give or take, youd have to just go to a dealer and talk to one of them and get like a quote.
Old Mar 10, 2009 | 10:30 AM
well thank you i hope its no more than $500 thanks for your help
Old Mar 10, 2009 | 01:52 PM
Swerve's Avatar
Thats what happened to the motor in my warrior, exept after I got mine free I ran it and destroyed the most of the internals. It was going to cost over $1000 to get mine fixed. Instead, I picked up a rebuilt engine off of ebay for $700.
Reactant
Mar 30, 2022 02:08 AM
ghost civic
Jan 15, 2020 07:43 AM
greg74
Sep 10, 2019 03:03 PM
Ashley S
Jul 31, 2015 09:46 AM
Reactant
Jul 16, 2015 10:29 PM
