Sheared Woodruff Key
Old Mar 10, 2009 | 07:45 PM
corbyzz's Avatar
Former Sponsor
Default Sheared Woodruff Key
What would cause a woodruff key to shear. I have replaced it twice, should I put loctite on it?
Old Mar 10, 2009 | 10:07 PM
91Warrior357's Avatar
something would have to be loose or missing a certain bearing to do that, this is the key that sits in the crank then the flywheel/stator slides over it? if so there should be a cage bearing that slides onto the crank and it sits inside the flywheel/stator when u install it, if that bearing is gone that would prolly cause the key to break.
also one little trick is to try and make a little nick on the key so it has to be forced into place if you know what i mean that way it doesnt just sit in there loose, once i put a little nick into the side of it i use a hammer and gently tap the key in place.
Old Mar 11, 2009 | 07:47 PM
corbyzz's Avatar
Former Sponsor
bearing cage is there, I have surfed other forums and some mention to loc-tite the fly wheel to the shaft. What do you think 357?
Old Mar 11, 2009 | 08:49 PM
i dont think ive ever heard of that, never hurts to try id give it a shot, after i make a little nick in the key and tap the key in place with a hammer its it there pretty snug and ive never had any problems afterwards.
Old Mar 13, 2009 | 11:53 AM
corbyzz's Avatar
Former Sponsor
well its in and setting up right now, should know tomorrow.
Shav0
Oct 23, 2004 11:04 PM
350wolverine
Oct 9, 2004 12:54 PM
lt250r85
Dec 6, 2003 10:17 PM
DietCokeOfEvil
Aug 27, 2003 02:31 PM
sweetcorn
Apr 20, 2002 02:43 PM
