Warrior starter noise
Old Mar 25, 2009 | 11:48 AM
sabotage17's Avatar
Default Warrior starter noise
Got a question hopefully someone can help me with. Sometime's when starting I can hear a pretty nasty clank coming from the starter ( like it binded itself on a compression stroke), also sometime's when I shut it down I get that noise. My question is: " is the starter engaged while the engine is running? and doe's it use some type of starter clutch?" Any insight would be greatly appriciated. On another note, anyone know where to get the headlight assembly for a 2000 Warrior?
Thanks, Sabotage
Old Mar 25, 2009 | 01:31 PM
Swerve's Avatar
Warriors do use a starter clutch and that noise is pretty normal. As far as a headlight assembly, I would just watch ebay or try something like BikeBandit.com.
Old Mar 25, 2009 | 04:41 PM
sabotage17's Avatar
I got to thinking that it might be somewhat of a normal thing, I had an Intruder that made a noise kind like that when you shut it down. The noise it makes sometimes when starting is what bothers me. Good call on the E-bay gig, I'll look around there and see what I can find. Thanks for the input.
Thanks, Sabotage
Old Mar 25, 2009 | 07:30 PM
91Warrior357's Avatar
yea its normal its the warriors one way clutch design that makes that noise, when i shut mine off sometimes it does it sometimes it doesnt.
Old Mar 25, 2009 | 10:17 PM
wildrunner09's Avatar
hey guys, i have a big problem,,,( just so were clear lol im a girl) when i try to start my 96 350 warrior , it cranks but it cranks backwards the same way the one way barring spins , could it be the wrong starter or is there any way the starter is running backwards? but it will pop start i have no idea guys please help if you can!!!! -
Old Mar 26, 2009 | 12:33 AM
atvman29's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: wildrunner09
hey guys, i have a big problem,,,( just so were clear lol im a girl) when i try to start my 96 350 warrior , it cranks but it cranks backwards the same way the one way barring spins , could it be the wrong starter or is there any way the starter is running backwards? but it will pop start i have no idea guys please help if you can!!!! -</end quote></div>
Can you flip the motor wires? That should reverse the direction of the motor.
Old Mar 28, 2009 | 11:13 PM
hey guys i just wanted to thank everyone for there advice, together with everyones help i got my wheeler fixed, the wires were crossed going to the starter whitch made it run backwards, no more problems, went ridein last night and today ,,, thanks you guys!
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
black798
Sep 9, 2015 07:42 AM
Pahuntman
Sep 5, 2015 11:07 AM
ghost civic
Jul 19, 2015 10:13 AM
