paint
Old Mar 28, 2009 | 05:35 PM
hellya5029's Avatar
Default paint
would spray paint work for painting the plastics on my quad?
Old Mar 28, 2009 | 06:45 PM
JLsparky7's Avatar
Default paint
If you sand them real well and put a base coat of primer im sure it would hold up for a couple years.
Old Mar 28, 2009 | 08:59 PM
91Warrior357's Avatar
Default paint
krylon fusion and a few other paints work ok, as long as u do ALOT of prep work it can turn out ok
Old Mar 28, 2009 | 09:26 PM
05BigBear400's Avatar
Default paint
You don't have to do alot of prep to use the fusion paint.Clean the plastics real good then wipe down with paint thinner to get them really clean,then spray away
Old Mar 29, 2009 | 03:44 PM
WaaHeHe94's Avatar
Default paint
Krylon spray paint works really well on ATV plastic.When I bought a set of used plastic for my 1999 Sport 400 and painted it with the Krylon spray paint the only thing that I did was wash the plastic and then spray paint it.I think that it turned out okay.
Old Mar 29, 2009 | 04:11 PM
Default paint
hopefully it will last then, because with painting anything usually the more prep work the better, looks pretty good though.
Old Mar 29, 2009 | 05:08 PM
WaaHeHe94's Avatar
Default paint
The Krylon Fusion paint is a no-prep, superbond paint designed for plastic that doesn't require any sanding or priming.My main concern was that when the plastic would bend the paint would crack and come off, but so far it hasn't.It doesn't look as good as new plastic would or a professional paint job would, but I only have around $9 invested in my paint ($4.50 a can).I race my ATV's so the plastic tends to get scratched up and scuffed anyways.
Old Mar 29, 2009 | 07:28 PM
Default paint
damn, thats pretty cool then to not have to spend alot on prep like most over things you would paint, ill have to try it one day, from those pics it looks like it worked real good.
Old Mar 29, 2009 | 10:34 PM
free2blaze's Avatar
Default paint
I used krylon fusion, seems to be holding up fine, I washed my plastics real well, sanded out some scratches in the plastic and deglossed the plastic with some steelwool, than washed all surfaces with mineral spirits to make sure there were no oils on the plastics.
Old Mar 30, 2009 | 10:51 PM
beefy46172's Avatar
Loves To Ride!
If you properly prep your plastics and use Krylon Fusion for plastics or another comparable plastics paint it will hold up fine. It only looks as good as the time you put into it.
nachop
Feb 14, 2018 06:57 PM
95wolv
Jul 21, 2015 12:25 PM
Reactant
Jul 16, 2015 10:29 PM
hiofcer
Oct 5, 2000 04:43 AM
