Yamaha Warrior 350's Pros and Cons?
Old 12-09-2009, 11:41 AM
m16a2's Avatar
pros= cheap and the air cooled engine is very reliable, they still use same engine on raptor 350
cons= only battery start- no kick starter.
Old 12-09-2009, 03:48 PM
Swerve's Avatar
Older ones came with a pull start.
Old 11-06-2019, 04:43 PM
Warrior1984's Avatar
Default I don’t think so!!
I have an 1987 and doesn’t have a pull start. I’ve never seen the option.
Old 02-02-2020, 01:44 PM
my 87 has a pull start as well a compression relief valve in front of the engine.
  #15
Old 09-22-2020, 02:25 AM
Billy Buttons's Avatar
Default Think again
my 1988 warrior has electric and pull start cord. Not sure I would want to be pulling on the rope to start it if it was a cold start but after warmed it wouldn't be too hard to start. But you have to rotate the crank to the sweet spot to even pull a full rotation...if not then good luck pulling that rope and not damaging your wrist, there is quite a bit of compression or mine has a lot of compression...I use the electric start, it's just easier press the button and be gone😜
  #16
Old 09-22-2020, 02:26 AM
Default Think again
cherokee99
03-19-2009 02:48 PM
CoolCabritoCrew
07-24-2004 09:13 AM
Bruin350
01-20-2004 11:16 AM
hondaguy2
07-07-2003 01:05 PM
Snapper_Rider
08-18-1999 05:35 PM
Quick Reply: Yamaha Warrior 350's Pros and Cons?
