First post and new (to me quad)
Old Apr 5, 2009 | 11:03 PM
cleb's Avatar
Default First post and new (to me) quad
So I just got my first quad... a 98 warrior. Looked good and the price was right for me ($1000 - was this a good price?).
only obvious issue is the crank case is missing a bolt location (top one - looks like it snapped off and was repaired smooth) for the front sprocket cover. I figure I will rig something up to cover it.
I have a question. Getting it into neutral is a bit of a pain. It shifts fine and goes into neutral when off is easy... but when running it is a pain... any ideas where to start.
also... being new to me what should I do right off the bat to make sure everything is OK?
thanks
some pics
Old Apr 5, 2009 | 11:08 PM
Skatike27's Avatar
A grand! Thats a steal! Nice looking wheeler too. My 1998 warrior is hard to find neutral too, I wouldnt worry bout it to much, it is annoying though. I recently replaced my clutch and it helped out the problem a noticable amount. Good luck and have fun.
Old Apr 5, 2009 | 11:10 PM
91Warrior357's Avatar
looks like its in pretty good shape, id say it was worth $1000, i see it has an aftermarket front bumper and brush guards, some1 made a custom endcap for the pipe, things i do when i get a new used quad/bike is change the oil, new plug, clean airfilter, check tire pressures and check the valve clearances.
Old Apr 6, 2009 | 07:26 PM
beefy46172's Avatar
Loves To Ride!
Definitely looks like you got yourself a good deal there. Warrior's are known for having a hard to find neutral once they are warm. The only thing that I know of that really helps is installing an oil cooler kit--because you will notice over time, the hotter the engine gets, the harder and harder it gets to find neutral.
Old Apr 6, 2009 | 11:40 PM
JLsparky7's Avatar
You got a good deal. Change the oil to a 100% synthetic and drop your idle down and itll help with neutral.
Old Apr 7, 2009 | 12:14 AM
tylersdad06's Avatar
yea changed mine over to synthetic oil and adjusted the clutch a lil n it seemed to go itno neutral a lot easier. yea thats a great deal i gave 1100 for my 98 mines in just as good of shape but is blue
Old Apr 7, 2009 | 05:54 AM
cleb's Avatar
thanks everyone... I'm used to the clutch and shifting on my street bike. I just expected this to be the same... clutch pull requires much more effort then the street bike as does shifting... guess I will just have to get used to it.
I will be ordering oil filters, this week and will change the oil. Never did valves before but I guess I'll give it a go...
I am planning on pulling the exhaust this week and painting with bbq paint... probably pull the foot controls and paint them too...
one more thing... when I shut the engine down I sometimes get a clunk from the front of the engine. Is this anything to be concerned about?
thanks agian
Old Apr 7, 2009 | 08:32 AM
Swerve's Avatar
The clunk is normal. Just about every warrior does that. It's the starter clutch that causes that.
Old Apr 7, 2009 | 09:55 PM
cleb's Avatar
thanks... glad that it's nothing...
I learned something else new... unlike my street bike when you are not using the ATV you should turn the petcock to the off position. Left it open over night and found fuel under the ATV. Dripped out from a tube on the bottom of the carb... won't do that again
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
Frisky2050
Apr 9, 2020 11:19 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
