Dead spot in throttle
Old Apr 17, 2009 | 09:39 AM
Skatike27's Avatar
Default Dead spot in throttle
1999 Yamaha warrior. When you pin the throttle the engine bogs down and kills itself, but if you slowly push the throttle the thing will rev up. I know there is an accelerator pump in the carb and when you push the throttle it pumps gas towards the cylinder. What can I do to remove the dead spot.
Old Apr 17, 2009 | 01:32 PM
beefy46172's Avatar
Loves To Ride!
The pump is probably sticking. You need a good carb cleaning and to probably replace the accelerator pump spring.
Old Apr 17, 2009 | 02:39 PM
Rudedog's Avatar
Have you changed the exhaust, the intake or the air filter??? If so, the jetting could be lean... IE: too much air. Increase Pilot jet, possibly the needle setting as well. Any other changes?? You could also maybe have an air leak... If not, carb made need cleaning as was posted..
Rude Dog
Old Apr 17, 2009 | 11:44 PM
Skatike27's Avatar
No mods. I just finished cleaning the carb, is it possible its running to rich or lean?
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
JakeXBL
Sep 5, 2015 01:08 PM
sleepyva
Sep 2, 2015 06:32 PM
cody500ho
14
Aug 14, 2015 05:03 PM
