Warrior Front left caliper sticking
Old Apr 18, 2009 | 12:58 PM
Blueovalboy89's Avatar
Default Warrior Front left caliper sticking
I have an 01 warrior and recently put new brake pads on all around. They ran fine for a while, but now the front left caliper is sticking really bad. I was wondering if anyone else had ever had this problem or if there is any way to adjust the caliper. Any info would be great. Thanks
Old Apr 20, 2009 | 03:13 PM
Raptor450's Avatar
Probably need to rebuild the caliper, you can rebuild it easily. Just remove the caliper, remove the pads from the caliper, and pull the caliper piston out of the caliper. Replace the o-ring with one from Yamaha, clean up the piston, and reinstall everything. Don't forget to bleed the brakes!
Old Apr 22, 2009 | 03:23 PM
Well there is an allen head, what appears to be some kind of adjustment on the tie rod side of the caliper. And the one on the side thats stuck is tighter(or further into the caliper) which made we think this is some kind of adjustment screw. But when i tryed to loosen it (even with pb blaster) it broke ever allen i threw at it. .......?????
Reactant
Mar 30, 2022 02:08 AM
Sandman2.0
Jul 21, 2015 09:03 AM
Reactant
Jul 16, 2015 10:29 PM
tporath
Jul 11, 2015 12:31 PM
traumajunkie
Jul 5, 2015 03:03 PM
