Warrior motor side case removal
Old May 18, 2009 | 12:57 PM
Wicked67dart's Avatar
Default Warrior motor side case removal
I recently got a 2001 Warrior and one of the sprocket cover mounts had been broken and patched with some epoxy. If i were to get a new side case, how hard would it be to pull the old one and install the new one? would the motor have to come out or can i just get by with it still installed? Any tips would be appreciated
Old May 18, 2009 | 01:12 PM
Swerve's Avatar
Man I wouldn't mess with it as long as it isn't leaking very bad. A lot of warrior's have that problem and most people just patch it. The motor would have to come out, you have split the whole engine and transmission. Your looking at a lot of work
Old May 18, 2009 | 01:55 PM
tnwarrior82's Avatar
i have the same problem but i havent patched mine yet.what can i use to patch it.
Old May 18, 2009 | 02:06 PM
Swerve's Avatar
Well I still had the pieces that broke off the case so I used JB weld to hold the pieces back in place. Depending on how big the hole is you may be able to use JB weld to fill it.
Old May 18, 2009 | 06:27 PM
91Warrior357's Avatar
yea that is common on warriors mine was like that JB weld didnt work all to well but they make an epoxi that bonds to those cases better then JB will but i forget what the name is, i just welded mine back together.
Old May 18, 2009 | 08:37 PM
free2blaze's Avatar
I recently got a 93 warrior, mine had been broken and welded by the previous owner.
Reactant
Mar 30, 2022 02:08 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
rcappie4
Jul 10, 2015 04:54 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
