98 Warrior Wireing question
Old Jun 14, 2009 | 12:45 AM
Wookie11's Avatar
Where do they go??? thats the big question. All I see is the two wires that are in the same bundle coming out of the wire harness (one being black with a yellow line going down it and the other being solid black). I dont have any clue what i'm sopose to put them back into? Please explain. I havent found any other wires at all that these came un hooked from. So thats where i'm at at this point. I need to know where thoes wires have to go. They were tucked under the hood and they are long enough to hang below my front bar. Somebody please help... Webbl19 I think your on the right path.....
Old Jun 14, 2009 | 12:47 AM
Wookie11's Avatar
Both the wires obviously go to the same place because it is a doubble wire (meaning together).
Old Jun 14, 2009 | 02:17 AM
91Warrior357's Avatar
if you had a picture i could tell you right away most likely, but look at the plug thats on the key switch under the hood and see if it seems like it goes into that at all, or around the ign. coil...what kinda wire connector is it? theres the bullet style which has a male and female end to it, and they connect into eachother, thats what the wire coming off the clutch perch is, the parking brake sensor, most people unhook those and plug them into eachother creating a loop
Old Jun 14, 2009 | 10:28 AM
webbl19's Avatar
he says it goes to the clutch.
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Mar 30, 2022 02:08 AM
Reactant
Jul 16, 2015 10:29 PM
tporath
Jul 11, 2015 12:31 PM
D-Hagz
Jul 4, 2015 02:19 AM
