Top Speed?
Old Aug 21, 2009 | 01:31 PM
scootergptx's Avatar
Supersock
Hired Gun!
As far as top speed goes, don't expect more than (just a guess here) 50-55 tops.
Have you had the quad since it was new? Once you get the carb/fuel mixture figured out, you might see if someone didn't change the sprockets too. You may have some good low end, but at the price of top end speed.
Old Aug 21, 2009 | 01:32 PM
Supersock
Hired Gun!
Originally Posted by huntingtrc
Thanks, i'll tear it back apart and take another look then.
If you can, get a compressor and blow out all the jets and seats.
Old Aug 21, 2009 | 02:08 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Alright, a understand what you are saying. I have a 1998 Yamaha Wolverine 350 4x4 she starts right up and idles great. When I am running it wide open in 5th gear she is only at about 31mph and is real doggy. I have pulled the carb cleaned jets, changed the plug, and I am trying to figure out what I should expect out of this machine.
Hey thanks for being a good sport man, we aren't trying to be an a-hole toward you, just having fun. I'd focus more on the main jet if it's a top end issue. Clean the carb and filter good and see if that helps. Any backfiring going on?
Old Aug 21, 2009 | 02:17 PM
huntingtrc's Avatar
I bought this thing used and it has been riden pretty hard and not maintained the way it should have been. I am not sure what the first guy did with it but I am seeing more of what the last guy did or didn't do everytime I look at something. So all in all I have several seals that need attention and I gotta get this power thing figured out.
I will pull it all apart tonight and see if I missed cleaning a jet and hopefully find the problem. Thanks again guys!
Old Aug 21, 2009 | 02:30 PM
  #15
Koopa's Avatar
26" are pretty tall for a old 350. Not sure what stockers are. Maybe just more than the thing can handle in combination with being abused. Check the compression, may have worn out rings.
Old Aug 21, 2009 | 10:56 PM
  #16
BlueBlaster's Avatar
Stock Wolverine tires are 23 inches tall. If there are no performance mods to the machine it will have a hard time turning tires that are 26 inches tall. I don't understand why people put huge mud tires on the Wolverine, it was never intended to be a mud machine, it is a sporty 4x4 that is intended for trail riding. I am guessing that the quad was purchased with the tires already on it.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
