Rims iside/out...is it that bad?
I took off the rims of the shee, and mounted them the inside out (on purpose) to see what changes it would do. I gained 1-2" in width, BUT, my brakes seem very exposd and the valve should be relocated (no big deal). What other bad stuff could happen? I guess bump steer, more bottoming maybe...what advantages? stability? look?(<- YES).
Someone stop me if I'm doing a big mistake!!
what i did is where the original valve stem is took a new one and turned the valve stem around so it would face the inside of the rim so it would be inside the tire and on the other side of the rim opposite of there the original valve stem was and i drilled me a new hole and put the valve stem in the right way and now u have the front rims turned around
