question about warrior crank
Old Sep 2, 2009 | 08:35 PM
yamahawarrior1986's Avatar
Default question about warrior crank
i have 2 warriors. one runs great and has many upgrades. the other i bought from a friend for parts. he said he locked it up. i got it home and put in a new battery and a new plug. it crunk up! i couldnt believe it. i only gave 200 dollars for it. it knocks like crazy. i took it apart and the main bearing l0oks broke. would that make it knock in idle? thanks for the feedback
Old Sep 3, 2009 | 08:53 AM
Swerve's Avatar
I would think so. The engine in my four wheeler was "locked up" when I got it. If I would mess with it for a while it would start but make a horrid knocking noise. Then the next time I went to start it it would be "locked up". I had a rod end bearing go out and it would just bind up sometimes. Everytime the cylinder goes through a cycle it is going to knock. That motor will probably need completely rebuilt.
Old Sep 3, 2009 | 03:40 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
sounds like a fried lower rod bearing... really the only way to blow a warrior up is neglect. either dirty, imporperly installed, or missing air filter. and low or no oil..
Old Sep 3, 2009 | 08:12 PM
91Warrior357's Avatar
youll need to at least get the crank rebuild, new bearings, thrust washers and rod and stuff.
Old Sep 3, 2009 | 08:41 PM
ok thanks for the help
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
toonces
Aug 5, 2015 05:55 PM
Reactant
Jul 27, 2015 07:45 PM
