05 Grizzly 660 Carb Help!
Old Jan 3, 2010 | 03:20 PM
adamztoyz17's Avatar
Default 05 Grizzly 660 Carb Help!
Hi,
I have been riding my Grizzly occasionally and its been stuttering and sputtering and many times I have had to have it at full choke for quite some time and later moving it the mid choke. Yesterday I had my fill out it and decided to take the carb off. I did good until I got to the part where there is a cover with three small screws and inside is the end of the throttle cable. Well I looked at my manual and it appeared you needed to remove the two allen screws, but it didn;t work well so I finally got the little brass piece off, but the spring piece in there appears to have lost its tension. When I press the throttle there is no tension is is just loose. I have tried to move the spring and once got it to where it seemed it might work, but it was a no go. I am getting irritated and am about ready to go buy a new Edelbrock carb. I need help with the spring and also would the dity carb cause the sputtering and clonking out? I used this to plow and we just got a ton of snow. I did notice the previous owner jb welded the bottom of the float bowl. Is the spring part solveable or do I need to go to the Yamaha Dealer? I am sure the wait would be two weeks. I can't afford to wait that long. Please help!
Old Jan 4, 2010 | 11:19 PM
grizzly4x4660guy's Avatar
Lightbulb me too
i have the same atv had the same problem. mine had sit for a while n started crapping out on the throttle. i jus ran some b-12 chemtool (fuel cleaner) and high octane gas and rode it more often. it runs like brand new now. hope this helps.
RedRancher
Oct 15, 2020 01:45 PM
greg74
Sep 10, 2019 03:03 PM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
