95 kodiak 4x4
Old Feb 23, 2010 | 06:06 AM
doughchvy1's Avatar
Default 95 kodiak 4x4
hello everyone. i am new the atv seen as this is my first atv that i have owned. it is a 95 kodiak 400 4x4 with 1900 miles on it. it seems to run good and no problems as of yet just want to get some others opion on this atv and what i should look out for.
Old Feb 24, 2010 | 04:12 PM
dupont's Avatar
I have a 1998 and its a tank. the only thing That needed to be replaced was obdviously the oil and air filter . But other then that the battery, tires,starter, and the rear hub rounded out but other then then the starter and hub, those other things are just wear and have to be replaced no matter what. My speedomitor stoped working like 3 years ago at 8,8XX hours witch I feel no need to fix. that is alot of hours and only replaceing the starter and hub.
Old Feb 24, 2010 | 05:13 PM
doughchvy1's Avatar
is your valve train noisey on your, or should i be looking into doing a valve job on this machine. just put a sparky spark aresstor on it and it seems to be running good just little noisey.
Old Feb 24, 2010 | 05:15 PM
dupont's Avatar
I dont hear anything on mine. Although on my 2003 yamaha warrior 350 I do.
Old Feb 26, 2010 | 10:39 AM
95kodiak400's Avatar
I have a 95 kodiak and i absolutely love mine. ive had it almost handle bars deep in water and mud and never had an issue with it. runs great. just had to rebuild the master cylinder cause it went out. but hey, i guess 15 years on the original parts is good. heck, im still on my oroginal tires.
Old Feb 26, 2010 | 01:55 PM
dupont's Avatar
I did have a problem with my 98 kodiak in 2 feet of snow last night. I had to walk to my house get a shovel, go back and dig it out. Then when I was trying to put it away It got stuck again. luckly the second time I had my shovel with me.
Old Feb 26, 2010 | 07:20 PM
dupont's Avatar
Here are some pics of my kodiak stuck in deep snow.
Old Feb 27, 2010 | 05:24 AM
doughchvy1's Avatar
i have had mine out in about a foot of snow and it just plowed right thru it.i just got this quad so i have been out doing little work here and there to it just noticed that there is not brake light just tail lamps on this. whats up with that.
Old Mar 1, 2010 | 04:24 AM
doughchvy1's Avatar
well over the weekend. i went thru and cleaned the carb out. went to do a simple oil change and found out they guy before me rounded off the drain plug. that was fun but was able to get it out. looks like the guy hasnt done a oil change in a couple years. oil had gas in it and some metal shavings that im not to fond of. i guess i'll be doing another oil change here in a couple of weeks and pray for no more metal shavings. other than that the quad is up and running great.
RedRancher
Oct 15, 2020 01:45 PM
YankeeRebel
Oct 6, 2015 06:44 AM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
