Moto 4 Ignition Timing
Old Mar 23, 2010 | 03:10 PM
wrosales's Avatar
Default Moto 4 Ignition Timing
Can you adjust the ignition timing on a moto 4? I have set the intake and exhaust valve clearing and it is in time correctly. I am thinking the ignition timing is off because I took the carb off and when I look through the intake valve I can see the spark plug ignite. It will fire once and shoot fire out the intake valve. Any ideas?
Old Mar 27, 2020 | 01:21 PM
Zach.mcanally's Avatar
Did you fix this problem I have one that does the same exact thing
Old Mar 28, 2020 | 03:39 AM
The ignition timing can only be out if the flywheel slips. T mark on flywheel must agree with true top dead centre by watching piston through plug hole. If they slip, they slip a lot so it should be obvious if it is out. If you set the valve timing by the T mark and the T mark is out, you will have set that wrong too.
stormnorm
Mar 6, 2020 01:01 PM
Oldsman67330
Feb 12, 2010 07:17 PM
ra3pt5or0rida
Jan 12, 2006 07:19 PM
Customfabandweld
Feb 5, 2004 06:53 AM
