need desprite help with warrior
Old May 4, 2010 | 06:01 PM
zaire1's Avatar
Default need desprite help with warrior
Ok i have a yamaha warrior that has no spark I got a brand new stator brand new cdi box new valtege regulater and new reverse lever I also got another wiring harness that came of a bike that I saw running when I put them all on turned the key on and as before both my nutrual and reverse lights came on tried to start and nothing took out spark plug to see if it had spark nothing when I put it in reverse both lights go out when its in nutrual and I put it in gear the nutrual light goes out reverse stays on can somebodey please help I am so stumped
Old May 14, 2010 | 01:41 AM
drstiddy's Avatar
not sure about both lights being on...im having the same problem with my warrior. but have you pulled in the clutch when trying to start it? as this allows one to be started in gear. just a suggestion. also did you check the coil or replace it?
Old May 17, 2010 | 03:19 PM
drstiddy's Avatar
keep us posted on what you find out as im curious how to fix this problem with both lights on as well.
Old May 17, 2010 | 10:17 PM
91Warrior357's Avatar
sounds like a wiring/ground problem somewhere on the harness check the harness over real good and the reverse lever, take it apart and make sure the contacts are good and grounds and everything and that theres no chaffed, burnt or frayed wiring grounding itself out or something.
Old May 18, 2010 | 02:33 AM
drstiddy's Avatar
i know mine isnt a ground problem as i had this harness on another bike that did not do it. but i changed the sensor an it quit doing it...however the light dont come on at all now. so i think its because this sensor could be bad. and if i start to unscrew the sensor whiles its plugged up...it goes out. so im gonna mess with the lever and make sure its adjusted correctly as i just put it back on from a frame up rebuild.
Old May 18, 2010 | 01:20 PM
Raptor450's Avatar
Make sure the stator and wiring harness match up. I believe the stator plugs are all the same but the plug wiring is different on some year models.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
