Banshee wont start after rebuild
Old May 9, 2010 | 08:40 PM
ATV24/7's Avatar
Default Banshee wont start after rebuild
2001. motor is professionaly rebuild wiht vitos stock crank and weisco pistons. it was rebuilt do to a thrown rod. i bought the bike liek this hoping to make a deal. the reason of motor damage was not known. it could have been a carbaration problem or possible a bearing. after cleaning the carbs and reinstaling everything kicks over smooth but not getting fuel into cylinders. fuel will drain out of bottom of carb though. does anyone have any experience or links advise of what to look for or at first? thanks in advance!
Old May 10, 2010 | 07:25 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Originally Posted by ATV24/7
... fuel will drain out of bottom of carb though...
Do you mean you are taking it apart and checking or it's coming out by itself? If it's just pouring out than I think it's probably coming out the overflow which means that something is up with the float. That would keep it from starting to.
Old May 10, 2010 | 03:25 PM
ATV24/7's Avatar
no, my bad. gas will flow thru if you crack teh drain screw on teh bottom of the carb. i took the carbs off and cleaned teh jets and that out before reinstalling. its not somthing in that tors bs is it? they are unplugged. it was liek this wehn bought so i figured it ran like that fine. tell me if im wrong
Old May 10, 2010 | 09:50 PM
ATV24/7's Avatar
so noine has anything? no suggestions? questions? thoughts? ideas?
Old May 11, 2010 | 01:05 AM
1996dragshee's Avatar
If you have fuel in the carbs and its not firing...that sounds like an electrical issue. A few quick ways to check for spark..a little starting fluid with new plugs straight in the cylinders and kick it.If you have spark it should at least fire over. If not then disconnect the TORS..all of it....that is all garbage anyways and is a known problem for loss of spark out of no where.Disconnect the control unit, the carb switches, and the throttle switch (the parking brake switch is wired to the CDI)
If the tors isn't the issue it could be a bad coil or stator.I'd bet my money on the tors/parking brake though. Let us know how it goes
Old May 16, 2010 | 07:17 PM
ATV24/7's Avatar
ok sorry for such the wait guys. i have been busy, and having computer problems. i got to mes with it for a while though today. after putting new plugs and checking the carbs once again it wouldnt fire on its own. i ut a little bit of premixin each cylinder and it ran on what was in the cylinder. somehow when it got tore down, the reeds got mis marked on top to bottom. this is my first banshee, so i know this is a quick easy answer, bu do the side with the 2 little fin marks go faceing upward or downward. when it ran they were faceing upward. and all this was done with all the tors plugged in like factory.
Old May 16, 2010 | 09:48 PM
91Warrior357's Avatar
the reed petals are supposed to face down, pretty positive. guess that your problem with them flipped the other way there no way the fuel can be sucked in.
Old Jun 6, 2010 | 03:25 PM
ATV24/7's Avatar
Ok im at a loss guys. teh reeds. are both sides supposed to be partially opened when installed? i not could that be a problem? cna someone post or give me a link to a picture of them. as of nw the reed are instaled and the two little markings are on thebottom facing the crankcase. it will start if you pu a little gas in each cylinder, but only idle until it burns it al out. please help out if you know anything! thanks
Scott-Leigh
Jun 6, 2015 09:10 AM
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
1000gade
May 27, 2015 12:37 PM
B4NSH333
May 26, 2015 06:55 AM
JakeGun
May 29, 2000 03:03 AM
