Yamaha Warrior Question
Old May 13, 2010 | 11:36 AM
MartinCBanks's Avatar
Default Yamaha Warrior Question
This maybe a dumb question but...
Can you hook a plow and winch up to a 350 warrior say 99-03?, i haven't done much research on it but i thought i could get a quick answer here
Old May 13, 2010 | 03:52 PM
91Warrior357's Avatar
i dont know of any kits to fit a warrior for a plow, warriors barely move in anything over 2 inches of snow, so plowing with one would be near impossible, a winch i have seen before mounted on the nose of the bike above the front bumper, an older wolverine 350 would be more fitting for that stuff.
Old May 19, 2010 | 12:54 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
It would be tough. Definately not going to push anything more than a couple inches. The real issue from my perspective is going to be weight distribution. I have a Warn county blade, and it is pretty heavy. You may be on the verge of tipping over forward with one like that. I know that there are some on the market that are fiberglass/plastic. Maybe you could use one of those. The real problem is going to be control. A two wheel drive is going to be uncontrollable. Even with 4 wheel drive, it is sometimes an iffy situation depending on the presence of ice etc. Chains are almost a necessity, and without the fronts pulling, I cant see you being able to turn. As for the engine size, I don't think you have any problem there, but you will have problems with a clutch setup. Automatics are way better for this. Lastly, how are you going to lift the blade? I know there are manual lifts, but they are a real pain in the forearm. You better eat your wheaties if you are going to use one for any period of time.
So with all that said, No, I don't recommend it.
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Mar 30, 2022 02:08 AM
toonces
Oct 16, 2019 12:11 PM
Reactant
Jul 16, 2015 10:29 PM
Jul 7, 2015 11:00 PM
