Problems with '01 warrior
Old May 14, 2010 | 01:32 AM
drstiddy's Avatar
Default Problems with '01 warrior
Hi guys, I'm new to this forum, but noticed there was all kinds of information and people willing to help so I decided to join. I have two '01 warriors and one is giving me fits. I originally used it for parts to fix one for my brother and now have gotten around to getting it all back together. Problem is...that I can't get it to start...well start then run. It has a white bros racing exhaust, jet kit, new stator and new high rev cdi. I know all the wiring is good...as I used it on another it runs great. It has great spark, compression is good, and valves have to set to specs. I had to put a new cam in it as the old one somebody beat a pin into since the factory one broke and it was out of time and could not be put in time. So I do know its in time now, carb has been rebuilt and jetted to specs. When I try to start it, with or without ether, it will try to fire and then it will fire and run for a few secs at a low throttle but will not rev. It does keep backfiring through the airbox when it does try to run, and will periodically backfire through the airbox when trying to start it. Cam chain is good and tight but I have no clue where to go from hear. Any suggestions or ideas? All info is appreciated.
Old May 17, 2010 | 03:09 PM
drstiddy's Avatar
nobody has any suggestions on this? i need help please and willing to try anything to get it going.
Old May 17, 2010 | 10:21 PM
91Warrior357's Avatar
just what kind of CDI is this aftermarket one? aftermarket CDIs have kind of been known to cause problems if its not a Dynatech CDI then i usually wont trust them, pro com and a few others have been known to just cause problems, try to swap CDI's off the other bike and see what happens, sounds like either a fuel problem or ignition/timing type problem.
Old May 18, 2010 | 02:31 AM
drstiddy's Avatar
im pretty sure it is a procom cdi. the thing is...it works fine on the other bike and is brand new. i have a stock cdi ordered and will be able to try it this week when it gets in...plus im gonna tear the carb apart while im waiting on it and go all through it again to make sure everything is clean. thnx for the response and ill keep you posted. if anybody else has any suggestions ill try them too. so you dont think its a valve problem? really dont wanna pull the motor again.
Old May 18, 2010 | 11:15 AM
well i was wondering about that also but it doesnt smoke right?
Old May 18, 2010 | 12:25 PM
drstiddy's Avatar
it has some smokey exhaust that pumps out as it cranks over, but it dnt appear to be a blue oil smoke.
Old May 19, 2010 | 12:21 PM
Dragginbutt's Avatar
Is old enough to know better, but too young to stop.
If you are getting backfires, you have a timing issue most likely. Check your cam specs again. You carb could be way off too, but I am putting my money on timing. If you got fuel and spark, then you are way off on when that occurs. The pop back is your queue.
Old Jul 9, 2010 | 11:45 AM
drstiddy's Avatar
but if it is in timing according to how you adjust it with the timing marks....then what am i supposed to do to fix it?
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
